View Single Post
Old January 7th 2007, 03:29
Veedub Veedub is offline
Originally Posted by oasis View Post
Below is a BBS RX-II that was part of the Wolfsburg Edition Jetta circa 2000. They are 16x6½ et42.
Here is what they look like. By the way, I have a 6mm spacer on the front and an 8mm spacer on the rear.
I like that, its nice.So if I got a 15x6.5, the slipstreams(i like them the most) with the +40mm offset with a 6mm spacer up front and 8mm spacer for rear, they would sit that far from the fenders? Did you have to narrow the frontend (unless thats a super) if so how much? Im just gonna swap the drums for drums drilled out for 4-100 pattern, I dont need disc brakes since my motor is basically stock, an small diameter tires an drums stop pretty quick. Would 195/60's work on 15x6.5 or 7's sine I have pretty new tires thats Id like to just swap over?
