The 944 spring plates for steel & alloy arms are adjustable for height, the toe & camber are more easily adjusted with both the alloy & steel arms.
You gain extra distance between the wheel bolt faces which can aid you when fitting Porsche off set wheels.
Of course you gain very good rear disc brakes.
