ended up like this:
Made up supports for the 996 turbo sports seats:
and sorted the 911 shifter
engine in to sort out mounts
bought myself a beadroller and made up some new floors
painted!
body needed modifying to squeeze the trans under the back seat
inner body cut away for engine room/access using a vw bus engien access panel that I chopped down
here some may notice the engine has been moved forwards and up in the chassis to give more sump ground clearance and to make sure the big quad cam heads fit under the bodywork
I then found some wheels I couldn't say no to, 19" Porsche carrera sports in Cayman fitment, 8,5J front and 10J rears
they needed the rear wings modifying to fit
by 45mm
front wings were massaged to fit as well as pulling the front suspension in a bit
I also added an air intake for an enclosed cold air feed for the engine
to go with all this, I modified the dash to take Porsche 944 VDO gauges, it will be covered in leather to look OEM
stainless exhaust system made up
Coolant lines made up to run under the chassis
which feed a cosworth Pace radiator and chargecooler up front
That's most of the story so far! I keep my website up to date so if you want to see more details have a look at
www.ricola.co.uk
It should end up looking more or less like this:
Comments and ideas welcome! Not finished yet, I plan to do the paintwork this summer when the weather warms up a bit... It's staying the same colour!
Rich
