Well the chassis tube is about 25kg, I'd say the rear end body mods probably balance out, then add the extra weight from the G50, subaru engine and cooling system... Not sure what it will end up as but shouldn't be too bad. The main thing I wanted was not to loose too much ground clearance and keep the chassis work hidden, while adding considerable strength.
One other main mod I will do is to add a shortened Kamei as everybody seems to rave about them so much! However, I don't like how they look so 'bolted on' normally, so I will cut it down and mount it to the body, keeping all the front valance panel and wings visible with the slightly shortened kamei below that in black, so visibly it should be fairly subtle. It should actually improve cooling to the radiator as well...
