so is the easiest way to go for the porsche early aluminium non turbo arms ?
something like this ?
ttp://www.cal-look.com/forum/cal-look-high-performance/porsche-944-trailing-arms-on-a-vw/
or
go with steel arms you won't need the 944 spring plates or drive shafts, you can either use the beetle items or transfer the brakes over onto your beetle rear arms. The Porsche arms are the same width as the beetle ones so you won't need wider wings or anything unless you go for mad wheels.
or is there another option ?this has been racking my head for months now . and what about the front end ?
