I relocated the brake master cylinder 30 mm to the drivers (right) side, this gives me enough room to fit a clutch master in next to it.
I now have to move the lever on the brake pedal over 30 mm as well and fit rose joint attachment to the clutch pedal to operate the clutch master cylinder.
I had Brad (aka Westy) weld some fittings on the tank. 1/2 outlet and and 2 x 3/8 return lines into the tank, while he was at it I got him to fill in the LHD part of the tank for some increased capacity, I think maybe 2 - 4 litres gain.
I bought this tank from a wrecker in about 2002 for my old yellow 1302, it was a genuine VW German replacement tank that looked almost new.
Reason: forgot photos
