View Single Post
Old January 6th 2012, 19:43
owdlvr's Avatar
owdlvr owdlvr is offline
Fitting of the porsche tach, at least in my '69 and '71 models, required some modification of the speedo hole. I had to run a deburring tool several times around the inside of the hole shaving out material, as the porsche tach O.D. is slightly bigger then the factory speedo. Will measure a factory speedometer shortly.
'71 Type 1 - Rally Project
'75 Type 1 - Family Heirloom
