View Single Post
  #158
Old January 10th 2012, 03:46
owdlvr's Avatar
owdlvr owdlvr is offline
Thanks! Occasionally I just want to "get it done"...but I know taking my time will make it so much easier to diagnose down the road. Considering the fact that I'm doing all the wiring without the battery or any testing, I'm either really really good...or insane :P
No photos tonight, as it's just more wires and connections. I've got the switch panel in the radio slot wired up to the relays in the trunk, speedo and tach 100% wired in at the dash (just the speed sensor to mount) and most of the modular panels powered and grounded. After that I started going through and labeling wires to make tomorrow night faster. With the techflex having to go over each wire, it wasn't realistic to label them as I built the harness. What I did do, though, was to bundle the wires by end location. Now when I'm trying to figure out "where does that wire go", as soon as I find that one wire in a cluster goes to the regulator (for instance) all five in that cluster go to the regulator. This cuts down the hunt-and-find factor, but considering there were 15 wires going to the relay panel...it doesn't necessarily make it quick!
I hope to get the rest of "my" wiring finished tomorrow, so that I can start installing the factory switches and their associated wires. There is going to be a LOT to stuff in behind there, and I'm not 100% sure it will all easily fit.
'71 Type 1 - Rally Project
'75 Type 1 - Family Heirloom
