View Single Post
  #139
Old April 30th 2013, 19:55
owdlvr's Avatar
owdlvr owdlvr is offline
Check my thread for possible consequences of not replacing the springs. It's in my latest post. The ones that weren't broken were 1/4" shorter then the new springs I put in. Noticeable difference in pressure required to remove/install as well.
3) Check VW / Audi wrecking yards. Cars from the 90's-2000's have a relay panel under the dash that unbolts. Usually 5 or 6 relay slots. You can get new terminal ends from the dealership (if you like spending money) or they use a simple 'keyed' female connector. Alternatively:
Bosch part number - 3 334 485 008 You'll need the terminals as well, but the people you buy the Bosch part from will have the terminals.
Painless Wiring - P/N 30108 is a 6-relay bank with wires.
'71 Type 1 - Rally Project
'75 Type 1 - Family Heirloom
