I just replied your PM Rioprelude (are you Alexander?), I don;t have a copy (anymore), but could Ricola not help as he had one he wrote in my topic?
iirc I disassembled it without manual ;-)
The 215mm 914 combo will not ever work as you need a clutch plate with G50/Mendeola spline. KEP makes 228mm (=9") Mendeola clutch you can use, but you need to swith flywheels then (as I did).
IIRC, no 215mm clutch plates (not even from Kennedy) are being made with G50/Mendy spline...
