View Single Post
  #208
Old July 21st 2015, 18:32
Car is back on the road, it lost power when the Tomei Pon cams were fitted, its a complete mystery, triple checked everything.
So I had the new Adaptronic ECU tuned on 98 RON and E85, its using a GM sensor so the ECU will adjust mixture and timing depending on the mix, boost is either low for 98 or higher for E85 using a Turbosmart eBoost.
The motor wouldn't take any more than 21 psi on E85 and would have an ignition breakdown, its running stock coil on plugs so I might be going to to LS2 truck coils soon.
It making 245 kW on E85 and has picked up a bucket load of torque, it hits very hard.
I setup a launch control through the ECU using the speed sensor in the G50 so at 0KPH its limited to 5000 rpm where it makes about 2 psi boost, as soon as the car moves 1 of the 8 segments in the G50 speed sensor tells the ECU to switch of launch control. It will be hard on the motor but Im only going to use it sparingly.
