View Single Post
Old July 26th 2015, 20:48
Originally Posted by owdlvr View Post
Simple solution to that. Run a brake bias valve, but place the valve in the front brake line before a T which then goes left and right. Gets a touch messy as you have to run the line through the bulkhead to the interior, and then back through the bulkhead to a T-fitting.
I saw a system years ago with cable operated bias valve, that would save running lines into the cabin
