View Single Post
  #16
Old September 26th 2015, 09:21
H2OSB H2OSB is offline
Originally Posted by proudbugowner View Post
Hi John! They have the same PCD with the 54mm sliding units? They also align with the stock 282mm rotor?
Thank you for your input!
Yes, they bolt straight on and align with the stock 944 rotors.
Your 944 calipers are actually 56mm. 56/36 front to rear might be fine for a heavy, front engine 944 but not so good for our light little rear engine Beetles.
johnL (aka H2OSB)
