Nice work, I welded the head of the front clamping bolt to the spring plate, otherwise its very hard to tighten it. I also bought a 36mm viscous clutch fan spanner on eBay to move the height adjusting eccentric bolt, the spanner is very thin.
The bolts on the rear of the spring plate sit much closer to the chassis on my car. I'm using Beetle inner torsion bar grommets and urethane 944 outers.
