Whilst it's been quiet for some time now, the project is still alive
Mainly been distracted/focused on renovating my home, will still take a bit of time and effort (and money :x) but still managed to make some progress on the 1303.
All zinc-coated parts are back, I'm not entirely happy with the quality, it's quiet flakey in a lot of places (see photo below), but I'm just going to use them for now, might get some of it redone in the future.
Also managed to order some caliper adapters as well as tie rods from Lanner, thanks for that!
And I've also received a front and rear set of widened fenders from Kerscher, they are quiet red so will definitely need a paintjob, but that will happen later. Mounted them with just a couple of bolts and without the fender rubbers just to get a feel for what they look like:
Looks pretty good I think. The rear isn't using the wide 944 hubs yet, so those should align with the edge of the fenders pretty nicely once I switch the hubs. The front I'm not 100% sure about but I'll probably need to move the spindles out a bit anyway to get the camber in a usable range so I expect that to be fine as well.
Current plan is to finish the suspension in the coming three or so months.
Need to make some modifications to the GWD spring plate covers since they obstruct the up and down movement of the rear suspension because they collide with one of the spring plate bolts/nuts.
Once that's done I can do some final measurements and order the shocks and springs for the rear and try to get it back on its four wheels
[edit] Added a photo of the car with the unpainted Kerscher fenders.
