View Single Post
Old May 25th 2009, 15:14
Hebster52's Avatar
Hebster52 Hebster52 is offline
In the mid January I started working on the exhaust.
Bought a pile of stainless steel 90 degree tubebends.
40mm OD and 37mm ID.
Had earlier bought a set of lasercut flanges:
The started to make my own exhaust.
Finding shorter exhaust studs was not the easiest task... They were M9 in the heads and M8 at the flanges...
So my Brother make me a set.
Here the first part of the exhaust is finished in mid February.
As you see in the last picture I also had plans on teststarting the engine with carbs first as I had a set of Type-3 carbs laying around.
