View Single Post
Old February 4th 2012, 12:55
-Alex- -Alex- is offline
Hello, i have been using solidworks about 6 years. I found few litlle weak spots from the bracket, so i redesigned it.
I am not using any preferred factor of safety, but bigger i get, better it will be. All tests have been done with 20000N=2000kg force. I tried also different directions the with same force on these uniball housings per part, i am getting 2 or higher factor of safety
I could try get the stress, strain and deformation charts. Bracket will be made still from S355 steel, but i would prefer Optim 500 highstrength steel, which also you can get up to 60mm thicknesses, the best material would be 7075 aluminum, but it would rise the price of this kit.
