hey and welcome...
I would put Drop spindles on if you are only running a adj Beam to fix the Camber angles and the BEST way to go would to buy Blank rotoreds and Drums and re-drill them and put a 12mm Stud in. you can get blank rotors from cip1.com
http://www.cip1.ca/ProductDetails.as...23%2D501%2D100
http://www.cip1.ca/ProductDetails.as...%2D075%2D113VN
and rear Drums already drilled...
http://www.cip1.ca/ProductDetails.as...23%2D501%2D301
hope that helps...
