View Single Post
  #17
Old February 8th 2013, 14:08
dub_crazee's Avatar
....i am speaking my thoughts here so please chime in with any of your thoughts.
I am running the saco slave AND MC. My gearbox has the same TOB release set up as the one pictured - with the omega spring.
Ive set my clutch pedal up to have 2mm of freeplay on the push rod - same as the brake MC. My pedal wont return all the way back (obviously as there is no return spring)
now......standard beetle has a return spring on the clutch release lever arm.
Am i right in thinking the porsche set up has a return spring on the pedal cluster?
I understand that the porsche box has the omega spring as a 'helper' spring but this seems to work the other way.
I am thinking i should probably try and do something similar? I just dont like the fact that my pedal doesnt return fully.
Classic Car Revivals
www.classiccarrevivals.com
