How are you two guys getting on with your brake conversions?
I have just made the 2 5mm spacers and inserted them behind the bearing seats. Whne tightened up there is still play, as if the bearings are loose. It appears that the spacers need to be a bit bigger then 5mm, I am going to check today, so will beable to report back.
On another note how compatable are the 4 pot brembo calipers with the vented disks from the sigle sliding caliper, there looks like a fair amount of difference between the thickness of the two disks.
Cheers
John
