View Single Post
  #16
Old August 26th 2006, 20:36
Humble's Avatar
Humble Humble is offline
Not much done today, got a pretty godd tan (burn) from spending all day thurs working on the car in the sun.
Mikey:
I really dig how you laid out the gauges in your dash I wanted to do something similar but put the tach and speedo in the center of the dash and the rest behind the wheel. I thought about hacking up the dash a little bit just to mount the tach and speedo higher for better view.
I want to shorten the oil pan but widen the bottom so i don't lose overall capacity and raise the engine but as little as possible to keep all the weight as low as possible. The exhaust actually hangs lower than the oil pan by almost an inch and nearly touched the ground when i got in the car
SuperRSi
No problem, all the nuts were finger tight. The exhaust is a megan racing header from ebay, I tried a couple different ones but settled on this one. I tried to fit it on backwards for you but the up-pipe doesn't clear the cam cover and to make it work you would have to add a few inches to the bottom of the up-pipe next to the flex coupler to make it clear.
