View Single Post
  #32
Old February 10th 2014, 17:15
Back on with this a little. After viewing this thread after some crafty Googling http://www.thesamba.com/vw/forum/vie...r=asc&start=38 I've seen that the old seal used to be much thinner than the new 13mm one. This gives an extra couple of millimetres that can be shaved from the mounting face. That might be enough to slip in an adapter plate and retain the proper clutch actuation distance as measured on the beetle box.
The replacement seal that I've been eyeing is 22x40x8 with a twin lip http://www.bearing-king.co.uk/bearin...0-x-7-r23/8798 and at only 7mm thick means that there is potentially nearly half of the boss area that can be milled away. This seal appears to be from a Yamaha bike front wheel. But so long as it does the job I'm happy.
A seal and exploration of a scrap gearbox case will have to wait, but it does look promising
That is of course unless someone is feeling very flush http://www.ebay.fr/itm/Butee-embraya...item461a6e906b... €450 is a little too much for me
