Originally Posted by nbturbo
.I was running 20.5 Lbs/hour injectors and have changed them to 18.25 Lbs/hour and it's running real sweet with just the normal 4 cylinder chip.
18/20 lbs-h seems really too little low, unless you use twin injectors of these...
A good 2,7 needs about 40 lbs injectors or 400 to 450 cc per min. I run 500cc´s and they could be smaller, tho it works well at the moment.
