View Single Post
  #173
Old October 15th 2011, 16:47
Bruce. Bruce. is offline
Are you using running boards? If not try them.
Otherwise the air flow as it passes under the rear edge of the wing might create a turbulent area as seen in the photos. Also the wheels out in the air flow also tends to create turbulence and drag.
