Once you get it sorted out, you can use the MS2 to control boost too. You can also use a pair of electic S/O valves and a switch, split the boost sense line to both the MS2 ECU and the manual boost controler, set one for 5 lbs and and the other for 15 lbs (ie. STUN and KILL settings).
