I've done more than remove the seat support, the original floors have gone in the scrap bin! I plan to use similar tubing for the front and rear seat mounts that will tie in the tunnel to the side members of the chassis. I'm toying with getting the whole lot galvanised when I'm done too. The whole lot is not that heavy surprisingly
A bit more done now...
Put the body on the chassis to get everything aligned perfectly before welding it all together
Years of bodges! Several plates, filler and pidgeon **** welding.
Front end together, nearly ready for welding...
