It's tough to tell from the photos but the inside front tyre looks a little light in the bends. In other words, the inside front is not planted and the front grip is mostly relying on the outside tyre.
It looks like the outer rear has compressed a bit far leading to the inner front lifting (the diagonal effect). I'd suggest a slightly tighter rear antiroll bar or perhaps ideally, slightly stiffer rear springs. A looser front bar might also work but more lean has other issues.
You could also try increasing the front rebound and see if that helps.
