View Single Post
Old October 6th 2015, 03:50
kai4130 kai4130 is offline
Originally Posted by proudbugowner View Post
I saw today that the 996 rear rotor is 75mm height and the 986 rear rotor is 67mm height, just to add the info...
I also tried the boxster (not S) rear caliper to the 944NA rear rotors but the brake pads overhang about 2.7mm on the outside, is this known and acceptable?
I hope not!!! Ive just ordered some 944 NA disc's 289x20.4mm. I've also got some 987 (non S) calipers to fit also. so same as yours
Lanner is sending me some of his brackets and this is the combination he recommends when fitting a 986 rear caliper to the 944 NA setup.
FYI the 986 ( Non S )rear disc is available in 292x20.4mm and 299x20.4MM, which could help solve your issue.
How is your caliper mounted?
NO that is not acceptable to have the pad over hanging the disc.
