View Single Post
Old August 13th 2002, 11:34
Oliver Knuf's Avatar
Interesting would be the tire size and where you want to drive the car, but from your statement I would use a low duration - high lift cam, like the VZ-14 to VZ-25 for 1.1:1 rocker use, or the more common FK-7 or the new FK-41 to FK-44 range for 1,4:1 rocker use, all from Engle!
There are some interesting profiles from Web-Cam, where I only tested a few, but the #218, split duration #218/#119 and the above profiles are pretty good. I tested most of the Type 4 cams, but some Type 1 cams, too. Take a look on both web-pages...
www.webcaminc.com
www.englecams.com
Click here to mail me!
