If you are running a 911 style fan and a good shroud you won't need those tins,they dont work well with other shrouds.They only work with the Klaus shroud because there is a hose that goes from the shroud to the tin.With your aluminum cylinders you won't need tins anyway and they wouldn't fit properly either.Also, you want air to pass through the cylinders from above.It doesn't make sense to blow air from the bottom that collides with the downward air.The heat needs to escape from the cylinders and heads and not twirl around all over the place.
Send me the specs on your pistons,if they fit my application I may be interested in buying them from you.
