The pics there are for 944 aluminum backing plates that have been machined to retain the shortaxle bearing. My concern with that is that the 944 backing plates have a grease seal on them that was designed to retain grease. When you put them on a swingaxle car, the oil leaks a little. The advantage of the 924T ones is that you can use youe swingaxle bearing cap, with the oil slinger. Anyone out there use modified 944 ones on a swingaxle? Any issues with oil seepage?
