If a pair of Type 181 differential flanges aren't obtainable, you can use what you have with +'87 944 S CV axles. They're the ones with the finer spline that's same as a Type I CV axle. Use the Porsche CV joint on the stub-axle end of the shaft, and the VW CV joint on the differential end of the shaft.
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
