Originally Posted by owdlvr
My fluid dynamics is pretty rusty, but considering it's essentially a dead-end on an oil line, I doubt it's moving around that much. Depending on your current oiling setup and how you plumb the accusump, it shouldn't add to the heat of your system.
It depends on which valve you use. If you have a manual valve that is full open while the car is running, is moving in and out of the accumulator whenever there is a change in oil pressure. The electric valve options can include a pressure sensor which can activate the valve to open ONLY when the pressure gets below a certain amount, say if it drops below 25 psi the valve will open or just open/close when ignition is on/off.
The other thing to keep in mind is the manual valves are typically a full port ball valve which, when open adds basically zero restriction so the oil flow happens very quick. The solenoid valves are typical a globe style valve which can add a considerable restriction. This just result in the unit not filling as fast after a being discharged. Which is why for a 'race' application they suggest using a manual valve only, and suggest the electric valve for the street.
