Originally Posted by levi20AE
what did you use to bend the arms? long pipe over the trailing arm ends? do you know how much camber 10mm gave you? this sounds like an opportunity to break out the tape measure and the trigonometry.
A big, hot, gas-axe flame. Yes, yes, I know about changing metalurgy etc but we got each upper arm cherry red, then bent them with a big piece of tube slipped over each arm held in a vice... That was about 200,000km ago
