View Single Post
Old October 27th 2010, 23:29
Luismj's Avatar
Luismj Luismj is offline
Originally Posted by kai4130 View Post
If your running a type one box in a type one then you should be able to get away with using the Saco kit as it's intended for a beetle and will "bolt on"
Are you using a Kennedy clutch? I was told by a local conversion garage that the Kennedy clutch (for my Porsche to Subaru) is a very stiff set up, possibly a little over kill but this is not helping my super still pedal.
Do you have any more information about the saco kit? (link or part number) He is really strong?
I'm use a race clutch similar the Kennedy and with the same weight problem .... need strong legs.
Pictures only to you understand my project;
New "truck" project... First steel prototype... (10/26/2010) And my forged bus water trans...
not easy, but i try!
CUP2 17x7x9 Brembo.w.Servo&Master.Cylinder/IRS/CB Dropped Spindle
GTI 2.1 16V Turbo Forged/Sapinho/Fueltech EVO-GL
