Any suggestions on which trans mounts to use? I have heard the OEM are stronger, but the urethane ones have the cutout which would require much less grinding. I feel a bit uncomfortable grinding off the extra material around the engine bolt holes.
Also, has anyone dealt with a trans with this tab on it? What was it originally used for? Suggestions on removal?
Thanks!
