Next, I hacked into the firewall behind the pedals to make room for the tilton floor mount unit. I also need to raise the pedals to clear the body and strengthen the floor so I made a spacer from 1/2" square tubing. Pardon the welding, I never welded before tonight. Somewhere a purist is crying, I can feel it...
I haven't decided if I need to brace the floor pan from underneath or not. I could tack in a couple strips of the 2x1/8" flat stock length wise for support if needed. Anyone else running floor mount pedals?
A couple of other odds and ends, I ground off the studs for the heater controls and finished removing the rest of the forward part of the spare tire well to prepare for the radiator/intercooler mounts and ducting.
Thoughts for another day...
As a result of the new transmission and mounting the shiftrod will now be above the tunnel. It will probably want to occupy the same space as the ebrake handle. No shiftrod in the tunnel frees up the tunnel for coolant lines.
