The donor S10 chassis.
Cutting the frame up. Removed some from the front, rear, and about 24" inches from between the wheels. You can see the vette wheels on. I used 2" aluminum spacers.
Ready to be welded.
Frame welded together.
Body sitting on frame for the first time.
Body cut so it'll drop down on the frame. The bottom of the body is flush with the bottom of the S10 frame.
