View Single Post
Old August 25th 2006, 15:40
Humble's Avatar
Humble Humble is offline
A little more progress on the bug these past few nights, some good some bad.
Got a few more parts in, koyo alu. radiator for a 93-97 rx7 turbo, 944 to beetle e-brake adapter swans for vdub engineering (very cool guys), wilwood clutch slave cylinder, and intercooler water pump from a 2002 ford lightning.
Test fitted the 1" spacers on the front and finally mounted the calipers (they don't fit without the spacers), and I tried the 2 sizes of fuchs that I have to see if they both clear inside and out.
6jx16 et36
I tried the 7jx16 et23 on the other side, I think it would be kinda sketchy but I can dial in up to 6 degrees of negative camber if needed.
Another project that didn't go so well is running my fuel lines. I ran fish tape down through the heater channel from the front and taped my fuel lines to it then tried pulling it back through. It got jammed right at the bottom corner of the door where it turns up and goes into the trunk under the fuel filler. I really want to use that route but I think it might neck down to small for the -8 and -6 AN lines.
