View Single Post
Old June 17th 2005, 14:49
SuperRSi's Avatar
SuperRSi SuperRSi is offline
Ricola,
If I can finish my Manx in the next few weeks, I will plunge into my 79 convert that I am going to install a 2004 US STi engine on a 930 trans. I have the Kerscher struts already on and the rear MBT coil-over set. I also have a set of Porsche GT3 radiators and A/C condensers for the front. Which trans are you going to use this time?
We seem to run parallel courses. My Manx got the Red9 setup after I read about your Speedster. So if you would stay about two months and several thousand $ ahead of me and then I can continue using your solutions.
Thanks,
Randy
