Quick question about mounting the G50 to the Beetle transmission cradle. It looks like the OEM rubber mounts are used, and then a metal plate with a tab, to connect the rubber mounts to the G50 bolt holes on the bottom of the transmission.
Is this plate custom, or is it from an OEM rubber mount (the bottom plate)?
