Originally Posted by Steve C
How well do you find your oil cooler works in the inner fender, I'm thinking of doing the same thing on my daily.
It works very very well in the fender well, far better than over the tranny. But, I have noticed nicks from rocks kicked up by the tire, which would be less of an issue if you're not running R-compound tires
The other issue/benefit is to get good air flow to the cooler you'll have to at least hole-saw/swiss-cheese the side of the engine bay but in doing so the fan on the oil cooler draws a lot of hot air out of the engine bay. I've also noticed slightly cooler head temps on that side when the fan is running.
