Feels like I'm picking up momentum again, as I near the completion of the transmission swap.
Trans mounted:
But had to deal with the Clutch cable tube (yellow) and Accelerator tube (blue). I knew from other forum posts that they were going to interfere, but with my trans being further forward then most...it's a bit extreme. From the camera angle it looks like the clutch tube is close, but it's just an illusion, the bowden tube wouldn't fit on it. The accelerator cable, is a definite problem!
Cut the sheet metal around the tubes, lightly bent them into a new position, and welded a new plate on. Simple simple, but yet another job that needed to be done. Oh, and here's a future problem, the bowden tube is 3" too short. I suspect I'll be making a custom bracket to use the shorter tube.
And, finally a lick of paint. Tomorrow I hope to flip the pan over and start working on some topside issues. With the body done at the painters, I'm on a time crunch to get it picked up.
