OK, I have a question for you guys. I installed one of the side windows, new seals, etc. It is super tight. As in, I broke one of the latches trying to close it. Eyeballing it, it looks like the alignment is a little closer to the lower edge of the window frame than the upper, but it didn't seem like there is any room for adjustment up and down or otherwise with the tiny screws on the hinge which holds the window frame. Thoughts/suggestions?
Do I need to just let the rubber set in place for a while (days or weeks) until it conforms to the frame, then try to latch it shut? I can't imagine Hanover having to do this, but I don't want to bust another latch again.
