Originally Posted by ECBug
Ive heard that the kits on CIP doesn't make it any wider. But if so you can always narrow the beam a little.
cool, for the frontend, with the disc brakes could i use a rim with a 38mm offset or do i still need the 40mm-55mm offset for front also, even with disc brakes and drop spindles, sine they do change the offset too.
