View Single Post
  #44
Old October 31st 2013, 02:11
SuperRSi's Avatar
SuperRSi SuperRSi is offline
Here is a look at the KMacs. Looks like camber changes will come with caster changes. Will reserve judgment until I try to make them work. Cast center section, I nestled the two together to show the cuts. Captive bolts for squeeze factor. Thrust bearing held in with C clip. Funny the box says you can change your Caster/Camber in only 30 minutes. We shall see!
