View Single Post
  #50
Old June 20th 2012, 07:53
That doesn't look like a problem at all: the front Mc Pherson struts are limited also by the shock's max downward travel. All other OEM cars also I think? Only inward travel needs an external limit as the whole car then needs to be slowed down. Full downward travel just needs to slow down the weight of the wheel and suspension. The down travel being dampenend by the shock's action anyways, so the 'bump' will be minimal I would think.
Why you think thats a problem or voids warrenties Turbonutta?
Limit straps originated from swing axle gearboxes imo where you didn;t want the suspension going extremely positive on camber ('tucking under the car') which caused lot of accidents back in the days iirc. If the shock isn't overly long, your CV's will cope and there is no problem. Or am I missing s/th?
