Yes, I did need to lengthen it quite a bit. Made this pic. You can see the welded piece in between, but I used quite some overlap, so the actual lengthening is a bit less than you think you see
Oh, don't mind the extra piece I made on the coupler. It turned out not to be neccesary.
