View Single Post
Old February 19th 2006, 01:22
ccain529's Avatar
ccain529 ccain529 is offline
OK, so I'm new here and I apologize if this is duplicated info!
I've been doing a lot of research and found this in the February 2005 HotVw's.
The info comes from Jon Chabot from TopLine
I tried to scan it, but it didn't take, so I recreated it! I hope this helps!
Like I said before, I'm sorry if this is repetitive!
According to the article in the magazine, This is a chart for fitting 17's under stock fenders of a 1302 or 1303. The article says that the 17's will fit under the fender with no problems. The problems occur when you try to lower the car and stick those super positive offset wheels under the fender. The article was written assuming you use 17X7's with the rubber listed on the chart. The article also cautions that your wheel spacers should be correctly machined.
