View Single Post
  #74
Old March 11th 2011, 09:16
Bruce. Bruce. is offline
The deutz cylinders look interesting. couple of Qs.
Are you using genuine parts or one of the many copies?
The cylinders are Ali, yes? Are they coated?
I thought that Ali pistons and cylinders don't go well together hence the usual plating options. I notice the Deutz pistons have a graphite coating to reduce wear.
Or are you planning to get the cylinders plated after the machining is finished?
